Hi everybody I have opened this Keil example problem UART1.c and compiled it...with Aduc7026 But this program is not giving output(Like printf("hello") on the serial port). I dont know why? Thanks in advance hameed
"I have opened this Keil example problem UART1.c ...with Aduc7026" What example is that? Where did it come from? Is it supposed to work with the Aduc7026?
From keil code examples C:\ADuC_Beta702x\Code\Keil Code Examples\UART\UART1 #include <ADuC7026.h> extern int write (int file, char * ptr, int len); // Functions used to extern int getchar (void); // to output data extern int putchar(int); // Write character to Serial Port int main (void) { unsigned char jchar = 0x30; char output1[13] = "Hello World\n"; // Setup tx & rx pins on P1.0 and P1.1 GP1CON = 0x011; // Start setting up UART at 9600bps COMCON0 = 0x080; // Setting DLAB COMDIV0 = 0x093; // Setting DIV0 and DIV1 to DL calculated COMDIV1 = 0x000; COMCON0 = 0x007; // Clearing DLAB GP4DAT = 0x04000000; // P4.2 configured as an output. LED is turned on while(1) { GP4DAT ^= 0x00040000; // Complement P4.2 write(0,output1,13); // Output Data jchar = getchar(); // RX Data, Single Byte write(0,&jchar,1); // Output Rxed Data } } so this one is the program which isnt giving any output. Thanks
