Greetings,
I have seen the user guide for the Configuration Wizard and to say the least it is terse. It lacks real explanation of what it is doing. By observation and analysis, I think I have some idea how it works. A more explanatory tutorial or example would have been helpful. If someone could update the user’s guide, it would be beneficial.
Has anyone attempted to use it for setting up the ADC and DMA? There are probably too many complications for this to be realistic, but it is a thought.
Big oops: I think you may have forgotten to mention what processor ;)
Ok, my bad. We are using the STM32F103RB.
Sorry, then no can help. I only have experience with some NXP processors, and then only using the configuration wizard to set up clock frequencies and memory interface.
Thanks anyway.
I would still like to see the "users guide" for this updated so it is a bit more useful. (Hint to technical support or whomever maintains it.)
Send a note to the technical support. At least that will produce a ticket in their support system and if too many pepole complains about the documentation they may decide to complement the it.
Ok, did that.
<soap_box> Now, anyone reading this thread. Do you find the configuation wizard user's guide instructional? If not, are you interested in implementing or at least understanding the operation. Then do what I did, complain. </soap_box>
Hello Leon Montgolf,
please see http://www.keil.com/support/man/docs/uv3/uv3_ut_configwizard.htm for more information about Configuration Wizard.
Best Regards, Martin Guenther
