message transmission through Ethernet
One of the application need to send & receive data through Ethernet using LPC1768 microcontroller
For MAC initialization, PHY Device initialization and TCP/IP Protocol Stack,
we have taken reference source code "EMAC.C" & "TCPIP.C" from EasyWeb.uvproj (PROJECT)
The problem here is during transmission there is a delay of about a second.
Delay remains same for char transmission and as well as string transmission
I mean that data is not transmitting instantly (which i expecting)
But data reception through Ethernet is happening instantly without any delay.
But When i tried to send a large string (about 50 to 100 chars) characters are is missing.
Whether is it happening because of copying of data / chars from my internal buffer to TCP Tx buffer?
If yes, how do I overcome this issue?
Above stuff I’m trying on MCB1700 vers.1.2 evaluation board.
Any help in this is appreciated.
Regards,
Neman
  • I am using LPC2368 and using easyweb LPC23xx sample code.In this I am able to transmit Data but not receiving Data from Telnet application.. If you dont mind can i have look at your code or can u tell me when can i find sample code ??
