Hi, if I load the Blinky example program to MCBSTM32F400 demo board, then open the watch window, then I cannot watch any of the the APB1 peripherals (e. g. TIM2, TIM3, ...). I get the message <cannot evaluate> in the "Value" column.
Strangly the peripherals of the other busses work (e. g. APB2: TIM1, TIM8, ..., or AHB1: GPIOA, GPIOB, ..., or AHB2: DCMI, ...). But not really: If I want to change e. g. the value of GPIOG->MODER register, I cannot do this in the watch window (but I can do this in the system view window of GPIOG). (after clock enable in RCC->AHB1ENR in the function LED_Init).
Anyone can give me a hint, why the peripherals of APB1 might not be accessible in the watch window? I use the current uVision V4.54, and the original code of Blinky, directly from the folder Keil\ARM\Boards\Keil\MCBSTM32F400\Blinky.
I now found out the following:
In STM32F4xx.H the bus base registers are defined as follows:
#define PERIPH_BASE ((uint32_t)0x40000000) /*!< Peripheral base address in the alias */ #define APB1PERIPH_BASE PERIPH_BASE #define APB2PERIPH_BASE (PERIPH_BASE + 0x00010000) #define AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000) #define AHB2PERIPH_BASE (PERIPH_BASE + 0x10000000)
If I change the line for APB1PERIPH_BASE to the following:
#define APB1PERIPH_BASE (PERIPH_BASE + 0x00000000)
Then it works - then I can watch the APB1 registers also (just not modify them, but I can do this in the system viewer - this is quite ok for me).
Just perhaps somebody from Keil should look into this - I think this is really very strange.
... just tried in MDK4.60 - still the same strange thing (so to fix, it is necessary to adjust the STM32F4xx.h as described in my last post).
