Hi All,
I'm trying to debug an LP2294 (using a ulink 2) with RTX and external SRAM.
Most (not all) of the time it won't reset but crashes with a DAbt_handler error. So I look at R14 and it shows address 0x119FE inside the os_sys_manager: function. Take away 8 and you get 0x119F4 and the instruction LDR R0,[PC, #0028]. So I count 40 (0x28) instructions I get 11A1C with a value DD 8105FA00. Putting a break point there I see this code is called many times successfully
I have 1MB of SRAM memory at this location 0x81000000 so 0x8105FA00 is well within this. The memory is set up in Startup_RTX.s correctly. So I don't know why it is crashing like this when there is memory there? What makes it stranger is the fact that it works sometimes? I seem to remember a debugger delay being added but this is before it executes main().
Does anyone have any ideas?
To me it sounds like you are experiencing a buffer overrun somewhere that corrupts the RAM of the kernel. You may be able to find the root cause using a static memory analyser.
