Hi there,
While I understand how DPPs are used physically, I am having some trouble actually trying to use them in code! Here is a particular example I am stuck on, I have simplified it so hope I didn't leave anything out:
Boot_block SECTION CODE WORD 'Boot_Code' ; Located at 0x6000
version db 1 ; A constant located at 0x6000
init_boot PROC NEAR
mov r0, #version ; Move the address 0x6000 (constant) into R0
/\ This line wont assemble. Says "missing DPP information". I am not sure why it needs DPP information to simply load the address into a register as a constant??? This should translate to a mov r0, immediate instruction correct? If I add the following lines above the line that wont assemble as a test, the problem goes away. But, I don't want a DPP pointing at page 1!!! Can anyone explain please?
ASSUME DPP0 : boot_block ; Assume DPP0 points to page 1 (0x4000-0x7FFF) mov DPP0, #1
