Hello!
A function here starts like this:
uchar uc_Check_Limits(uchar pdata *ptr_Set,struct st_Limit code *ptr_Limit)small reentrant { union INT_CHAR data Value; uint uiLimit; // typ of limit EA=0; Value.byte[0]=*ptr_Set; ptr_Set++; Value.byte[1]=*ptr_Set; EA=1; ...}
The union is defined as:
union INT_CHAR // Union zur Konvertierung { Uint16 word ; // von char zu int und umgekehrt signed int sword ; Uchar byte[2]; signed char sbyte[2] ; };
I'm using Hitop debugging software. If I add Value to the watch list, Hitop says Value is on memory I:0xF0. So Value.byte[0] should be on I:0xF0 and Value.byte[1] should be on I:0xF1. But the compiler generated code copies the first byte of ptr_Set target to I:0xEF and the second value to I:0xF0. If I manually edit Value.byte[0] in Hitop, it is written to I:0xF0 and if I edit Value.byte[1], it is written to I:0xEF. I can verify that in the RAM viewer starting at I:0xEF. It looks like the bytes are accessed in reversed order here. What is wrong here? I can not see there's something special about the used memspace.
Thanks in advance for any clue.
