I have include a c file with #pragma SRC after a build of my target, I have include the .src file in the projet for future use.
but after all build (compilation) of the target, I have a BL51: WARNING 7 (MODULE NAME NOT UNIQUE)
I think that is because the c file give a obj file with the same name of the src file, I have try to do the explication of this page:
http://www.keil.com/support/docs/635.htm
but I can't find the "Include in Link/Lib" checkbox?
I use µvision3.
thanks for your help.
See: http://www.keil.com/support/man/docs/c51/c51_src.htm - and note the four steps for using such a file in your project.
You should not add the .src file to the project!
(or, if you do add the .src file to the project, then you must remove the .c file).
thanks a lot for your answer.
I have do this and all is correct now.
thanks.
