I have a setup where i use RL-ARM V4.01.
I have 2 network drivers with same problem, one for ENC28J60 and one for ZG2100.
The drivers seems to work, i can continuesly ping the ZG2100 with 1450bytes. (what is the maximum number of bytes?(for testing)?
I have saved the index.htm and other files on the SD card.
when i run the htpp://ip it loads the index.htm from the SD card. In the index.htm there is a picture in a sub folder there is linked to, this picture can not be loaded :( (debug says can not find file)
I also have a .txt file on the sd card, when i run htpp://ip/test.txt it just give me white screen in IE7 and no errors in log. Mozilla trys to download a empty txt file.
I have ofcause the retarget & HTTP_uif in my project.
Someone who has an idea what i could look for to solve this problem?
Thanx
I am also facing the same problem.
Do you have solution for this now?
