dear all, i m interfacing 7366 with c8051f120.
according to datasheet of 7366 its clock is 5Mhz (100nSec and 100nSec of SCK high and low pulse)
pls tell me which lines of among 4 pins i.e mosi,miso,nss,sck are pushpull and open drain.
because i made mosi as pushpull and rest as opendrain
i have given pullup to miso,nss,sck
i have written the code according to sample program.
and the sequence of the code is running according to timing diagram of 7366
i am writing 0x03 in MDR1 register and reading it
but i still receive 0xff or 0x00
i even have problem in sck display i.e clock doesnt get displayed properly
pls tell me where i m wrong.
spi settings are: spi0cfg = 0x40; spi0cn = 0x0d; spickr = 0x00; for 5Mhz (datasheet of 7366 under ac characteristics of 5V)
i m using spi in interrupt.
pls replay thank you all
hello everyone pls help me out thank you all
c8051f120. pls tell me which lines of among 4 pins i.e mosi,miso,nss,sck are pushpull and open drain.
config2 will set the pins correctly
thanx erik for the replay,
my problem is solved.
it was the operating frequency which was creating a problem
i have set the frquency < 1Mhz and now it is working fine. i.e reading and writing of registers is done properly
now i m connecting rotary encode of A,A/,B,B/,Z,Z/ input to 7366 but my voltage signal drops to 2V.
and i m now unable to read the configuration of internal register of 7366, without connecting encoder i used to write and read but now it is not happening
even i am unable to read pulses of rotation even though i rotate the shaft
pls help me
thank you take care
