When A51 encounters an error during the expansion of a macro it gives error line references to the original source file that are wildy incorrect. These are in the output window in uV3. When you then go to the referenced line #s in the source file the code there is not in error. When you go to the related listing file(.lst) the errors are underlined & described as to nature of the error. At the site of the error notations there are references back to the source file lines that disagree with the actual locations of the errors shown in .lst. but do agree with the erroneous line #s in the ouput window. I blew some time trying to figure out what was wrong with the referenced source lines before I realized that the errors were elswhere. Both the .lst error line #s differed from the invalid .a51 lines by decimal +300.
try include the macro expansion into asembler and you get the line!?
I use macro expansion & the listing file underlines the error OK in the expanded macro but gives a false source line referring back to the source file! Seems that it should give you the source line with the macro call in it that contains the error, not some totally irrelevant reference!
Is there an option to add or forbid #LINE xx defines to be added into the preprocessed file? Without them, the compiler will always display much too high line numbers when pointing out errors, since it will point at a line in the preprocessed file instead of the line number in the original source file.
I am using the A51 Assembler, not the C Compiler. Also my macros are written in the MPL format.
