Hallo, All!
These days I have migrated to newer Keil IDE version and found my older C++ project can not be compiled anymore. The IDE is installed and licenced correctly. If I return back to older version, everything is being compiled just perfectly.
Can anybody say what is wrong with my configuration (I reuse the same project) or with latest Keil version:
IDE-Version: µVision3 V3.53 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007 Tool Version Numbers: EC++ Compiler: EC166.Exe V1.09b C Compiler: C166.Exe V6.09a Assembler: A166.Exe V5.30 Linker/Locator: L166.Exe V5.22 Librarian: LIB166.Exe V4.26 Hex Converter: OH166.Exe V4.7a CPU DLL: S166.DLL V2.54 Dialog DLL: D167.DLL V2.48a Target DLL: MONITOR\MON166.DLL V2.42 Dialog DLL: T167.DLL V2.48
This tool-chain refuses to compile the source code (C++) containing expressions like:
... return static_cast <unsigned int> (myVar); ...
saying
error: Embedded C++ does not support the new cast syntax
THIS IS STRANGE since I used to use older version of Keil:
IDE-Version: µVision3 V3.21 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2005 Tool Version Numbers: EC++ Compiler: EC166.Exe V1.09 C Compiler: C166.Exe V6.02 Assembler: A166.Exe V5.20 Linker/Locator: L166.Exe V5.21 Librarian: LIB166.Exe V4.26 Hex Converter: OH166.Exe V4.7a CPU DLL: S166.DLL V2.49 Dialog DLL: D167.DLL V2.45 Target DLL: MONITOR\MON166.DLL V2.41 Dialog DLL: T167.DLL V2.45
which has no problem when compiling the project.
What am I missing?
Thanks, Nikolay.
"The IDE is installed and licensed correctly."
In that case, you should contact Keil support direct...
See the forum introduction: http://www.keil.com/forum/
I am using a slightly newer version (the latest I think):
IDE-Version: µVision3 V3.55 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2007 Tool Version Numbers: Toolchain: C166 Compiler/Assembler Kit Version: 6.10 Toolchain Path: C:\Programme\Keil\C166\BIN\ EC++ Compiler: EC166.Exe V1.09d C Compiler: C166.Exe V6.10 Assembler: A166.Exe V5.30 Linker/Locator: L166.Exe V5.25 Librarian: LIB166.Exe V4.26 Hex Converter: OH166.Exe V4.7a CPU DLL: S166.DLL V2.57 Dialog DLL: D167.DLL V2.49 Target DLL: MONITOR\MON166.DLL V2.43 Dialog DLL: T167.DLL V2.48
In this version
does not cause any problems and is compiled correctly.
This is because some version of uVision silently added the '--embedded_c++' option to the ec166 command line. This has been removed in the actual version of uVision.
Thank you, All!
Special thanks to "Gp F" who pointed the actual reason. It is the bug in UV3.EXE which has the --embedded_c++ string hardcoded in it.
Regards, Nikolay.
