uVision has generated a HEX file that it has trouble downloading via ULink. Very occasionally (1 out of 50), it will succeed. Other HEX files work reliably. Regenerating the file does not help. However, when I manually delete a line (record), seemingly any line, from the file, uVision is then able to download the file successfully. Target is ST uPSD3434. Can you help?
Thanks, Richard
IDE-Version: µVision3 V3.20f Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2005 License Information: Richard Edmonds Akai Digital LIC=CZVPR-K7G7L-TWK2Q-L4EQF-ZYPSU-1QV4Y Tool Version Numbers: Toolchain Path: C:\Keil\C51\BIN\ C Compiler: C51.Exe V8.00 Assembler: A51.Exe V8.00 Linker/Locator: BL51.Exe V6.00 Librarian: LIB51.Exe V4.24 Hex Converter: OH51.Exe V2.6 CPU DLL: S8051.DLL V3.00 Dialog DLL: DP51.DLL V2.46b Target DLL: BIN\UL2UPSD.DLL V2.58 Dialog DLL: TP51.DLL V2.45f Erasing PLD/ACR... Programming Flash Block 0 (FS0). Programming Flash Block 1 (FS1). Programming Flash Block 2 (FS2). Programming Flash Block 3 (FS3). Programming Flash Block 4 (FS4). Programming Flash Block 5 (FS5). Programming Flash Block 6 (FS6). Programming Flash Block 7 (FS7). Programming Flash Boot Block 0 (CSBOOT0). *** Error: Programming failed. Total Flash Programming time: 9.0 sec
Target is ST uPSD3433 Sorry for typo.
