Hi All,
I am trying to interface a simple 4x3 keypad i have never used 2051, i am using port 3. The pins i am using are p3.0,p3.1,p3.2,p3.3,p3.4,p3.5,p3.7
this is the basic code i am using
unsigned int keyData() { unsigned int i,j; P3=0xf0; i=P3; P3=0x0f; j=P3; return (i+j); }
call
switch(keyData()) { case 55: // Key 1 LEDR = 1;BUZZ = 1; key_delay();key_delay(); goto start; break; . . .}
I am considering p3.6 =0; i have put two pull ups to p1.1 and p1.0 i was told to do so when i asked my problem to a person i know.
i do not understand the working of the AIN pins may be that is where i am going wrong.
Please help.
Thanks, Ajay
"i have never used 2051"
"2051" alone is meaningless - you need to give the full part number, with all prefix and suffix letters & numbers.
Presumably you meant the Atmel AT89C2051? http://www.keil.com/dd/chip/2984.htm
If so, note that it's "Cx51/8051/MCS51" - not "C251/80C251/MCS251"
Hi Neil, sorry u r right its the wrong tool set. i will post in the right one thanks ajay
http://www.keil.com/forum/docs/thread10690.asp
