I trying to extract a u32 from a char array and the results are not what I expected.
Memory dump shows: 0xA0000680: FF 22 3C 87 01 00 A pu8Buf is set to 0xA0000680 pu8Buf+= 2; // value is 0xA0000682 pu32Buf = (u32*)pu8Buf; // value is 0xA0000682 u32Data = *pu32Buf; // value is 22FF873C Should it not have the value of 873C0001
Why was the data extracted from the addr pointer two bytes lower than the u32 address pointer locations?
0xA0000682 is not a word aligned address. When you used that address for word access, the ARM truncates the least significan 2 bits of the address for to make it word aligned, so the access was at 0xA0000680.
Thanks,
I changed my code to perform byte reads from the data buffer and order the data with logical shifts and or's.
The data that I needed to have from that buffer was
00 01 87 3c
in a u32DataItem
"The data that I needed to have from that buffer was"
That was my understanding. Did you accomplish it, or do still require assistance?
I was able to extract the fields correcly from the buffer. This was a buffer that was received over a UART from a data radio that implemented the ModBuf. I'm now processing all the responses from the commands that were issued.
Thanks for your help
