how to access an array in flashmemory
I want to store fixed strings in flash memory. How can I access strings
I tried following code, but this does not work...
My assembly file with the definition of the string
        EXPORT  TEST
        AREA    Example, CODE, READONLY
TEST            DCB             "TestString",0
        END
My C file that uses the string
extern  char* TEST ;
while (TEST[i] !=0) PutChar(TEST[i++]);
Any better ideas ?
Luc
