hi there, i am danish working on the project which included 2 X 8 7-segment display,AT89S52 microcontroller, v to f converter which act as ADC 24c04 eeprom etc. as step by step developing the code all thing are going smothly.but now when i want to add some code it give's the error as *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: _DATA_GROUP_ LENGTH: 001FH Target not created so i used xdata this solved the problem at the software end on computerwith "new" - 0 Error(s), 0 Warning(s). but when i used it in hard ware it disturb the display. can anyone help me in this problem.
How about posting the code ?
Have you read the error description and understood what causes the error ? You're trying to use more of a certain memory type than there is available.
Have you understood all the implications this "using xdata", and what this means for your program ? I.e. memory maps, or the need to activate the internal xdata memory of your chip first, or the slower access times of variables in xdata memory ?
Without knowing more about the code, any attempt at diagnosing the problem is pure guesswork.
as the internal RAM is full so using by XDATA i am trying to use the internal XDATA memory.
Does your particular chip have internal XDATA?
Does it need to be enabled and/or configured? If so, have you done that?
Remember, just checking the 'Use XDATA' box in uVision is simply for the information of the tools - it does not do anything to configure the target hardware.
