Hello.
I am using the EZ-USB control panel application from Cypress to download hex files.
The buttons with the names "Get Dev", "Get Conf", "Get Pipes" etc are working fine, the download also works fine.
My problem is when I am trying to send a command with the "Send" button located in the right of the drop down menu where one can actually selects the command that uses to send.
No matter what command I choose to send, the answer is nothing. I get nothing in the monitor of the EZ-USB control panel.
Anyone knows or even has a small suspition about this problem?
The reason I want this is because I want to test some code for replies in commands send from the Host.
Thanks a lot.
Sounds like a question for Cypress?
