Hi!
i am facing some problem, by interfacing a Nokia 3310 LCD with AT89C51 MCU. what i am doing is supplying the LCD +V from the 7805 Regulator and directly connecting it pins (SPI interface) to the controller, i have properly connected the pins and double checked it, i have also simulated the code in Proteus VSM , its working, May be i am missing some trick in real time, so can some Guru give me some idea so that i can run it, Thanks for the concern to read my message, Regards Ahmad Kamal Nasir.
Are you sure that the LCD itself actually works?
I also facing the same problem that as you face.... did you have the output already? Is it the initialise reset problem? Or other problem?
Have you read the manual of 3310? In the version I have,it's supply is 2.7-3.3V.
yeah, you are right guru. after supply modifications the problem has been solved thanks any way!
So lucky you! I have destroyed serval 3.3V devices by connecting them to 5V...
can u please send me code and configuration u made for nokia 3310 lcd. i am really in need to interface 3310 with 89c51 mcu.
i would be thankful if u could help me.. please mail me saadlahori@hotmail.com
saad, its not written for AT89C51 controller!
