I am using Keil uv2 to program my AT89C51 and although the UART is working just fine in Simulation but in real circuit its not working i donno why .... cuz there are just ASCII code in the Hyper term but it was suppose to be "Hello to MCU " so could any one plese help me ..... any help is appreciable well my id is sirfrajput@hotmail.com
if it works in simiulation but not in 'real life' the obvious conclusion is a hardware problem
questions 1) I hope you are not one of those that believe that you can do RS-232 without a MAX232(equivalent)? 2) do you have a scope? 3) does hyperterminal give garbage or nothing when the uC send to it?
Well i know that i cannot communicate MCU without MAX232, and i have little knowledge about the MCUs cuz i have built one AT89C4051 with successful UART . but dont know the problem .. well as its my own created circuit so there might be problem and one thing that where do i send the Schimitics ?
and there is a garbage on the Hyper terminal.... and one more problem is that when ever i give power to my circuit all the LED's connected to my MCu are ON but they might have to be OFF cuz i have programmed them to be OFF until communication over UART ......... ant Garbage is comming when ever u RST the MCU.
that, most often is a result of baud rate mismatch.
well i have found the problem that was on MAX232 cuz its groung was not properly connected....
but there is one more problem that scanf is not working this is what i have written in keil
SCON = 0x50; TMOD |= 0x20; TH1 = 0xf3; TR1 = 1; TI = 1; printf("Enter the Meter no "); printf("and Shut down command\n "); printf("meter: "); scanf("%d",&i);
well on Hyperterminal all the printf words are shown but dont know why the scanf is not working cuz cursor is not getting any thing from me... why?
"cursor is not getting any thing from me"
Pardon??
why don't you try this type of loop for input.
char InputfromSerial (void) { while(!RI); RI=0; i=SBUF; return i; }
why don't you try this type of loop for input. and make everything come to a screeching halt when no input arrives.
see a psychriatist aboy your interruptifobia
Well the problem is solved cuz it was error in connection (Well cuz i am dumb) when i have set the flow control to none it worked like dream ............ but could any one tell me that why My mcu is giving the output 1 as 3 volt-dc but i think it might suppose to be be 1 for 5 volt-dc ?
I am using EXPRO-100 for program my AT89C51 and there is UART also in my MCU but the problem lies there cuz my AT89C51 is giving 3v for logical-1 and 0v for logical-0. but as far as my knowledge is working it might be 5v for 1 and 0v for 0. So could any one please tell me whats wrong (well UART is working fine and i am getting the required output from MCU via Hyper terminal)
"cuz"
Please, the word is "because".
"my AT89C51 is giving 3v for logical-1"
How are you measuring this?
Are you sure that the point you're measuring is at a constant, steady logic-1?
What is your power supply voltage?
Well sir i am measuring it with the Voltmeter and My power supply is of Steady 5v DC ....... and my desired output is of 5v because i am using external Digital Logic Circuit and My external Circuit is only capable to recoganize 1 as 5v DC............. may i know why?
Andy ask "Are you sure that the point you're measuring "
you answer "My power supply is"
Now, pleaase answer Andys question, my guess is that that will answer yours.
Hiya man well the answer of Erik's question is that i am measuring the voltage on the port .... IO port man well i know i am dumb but not that much that i cant measure the voltage
