HI, i am working on a project. I need to give extrnal data to input of buffer 74ls373 and at the output pin i receive data on pins D0-D7 which is given to the input to the microcontroller data pins (P0). I am using external memory for RAM and ROM.
My problem is when and how should I read data output pins of the buffer and store the output result into external RAM.
That all depends on how much memory you have, and on a lot of details of your hardware: the particular 8051 variant in use, your memory decoding logic and other things. This is a hardware issue. Keil tools have nothing to do with it, so you're off-topic here.
We think that you are getting ahead of your self with your approach. Please search this forum for the "bible" of 8051 operations. These manuals will tell you exactly how to buffer the data lines. Look at the schematics of some of the 8051 eval boards on this website for more hardware details. Look at the User's Guide for XBYTE absolute addressing. Bradford
"Look at the User's Guide for XBYTE absolute addressing."
Better, look at the User's Guide for locating 'C' variables in XDATA space, possibly in conjunction with the _at_ keyword extension...
http://www.keil.com/forum/docs/thread8419.asp#msg39177
