With RTL-ARM is it possible to have more than one interface of a given type (for example, 2 PPP interfaces)? Also is it possible to set up static routing between interfaces?
/dp
Currently RTL-ARM does not support to have multiple interfaces of the same type. You may however have active an ethernet and a PPP interface at the same time.
Static routing of packets between interfaces is not supported.
Franc
