Automatic Dependency Checking
I'm not sure if this is a bug or not, but so far, all the RealView projects I've worked on don't build like I think they should. Specifically, if I change something in a header file that's included in a project C source file and then press F7 to build the project, the C file that included the changed header file does not get compiled. Shouldn't it? Is there some option in the IDE I have to enable to make automatic dependency checking work so that doing a build compiles all C source files that have changed (via a changed included header file)?
Obviously, doing a build all gets around this problem, but there's no hot key like F7 that I can use to do a build all, and I'm so used to just doing a build via F7 that I often end up with an invalid target file downloaded to my board, because the build doesn't build everything that had changed.
Can anyone shed any light on this...?
Thanks,
Dave Sudolcan.
