MCB900, LPC938, A/D
I'm using the MCB900 with a P89LPC938 and the LPC900 development tools (demo version). I'm trying to test the A/D. Couple of things:
1. REG938.H doesn't list the A/D interrupt enable bit EADC (IEN2.1). So I added it to REG938.H:
sbit EADC = IEN2^1;   // ADC int
But afterwards, I get a compiler error:
REG938.H(184): error C146: 'IEN2': invalid base address
Any ideas?
For now, I bypassed it by doing this in code:
// EADC = 0x01;
IEN2 |= 0x02;   // Enable A/D interrupt
2. After much futzing around in the following code, if I set EA, it doesn't work; commented out, it works fine.
#include "REG938.H"
bit btADComp;
void main(void)
        P2M1 = 0x00;  // set P2 to quasi-bi
        P2M2 = 0x00;
        P0M1 = 0xFF;  // set P0 as input only (for A/D)
        P0M2 = 0x00;  // set P0 as input only
        ADCON0 &= 0xDC;  // disable all triggers
        ADMODA &= 0x0F;  // clear mode bits and boundary interrupt flag
        ADINS |= 0x04;  // select AD02 for sampling & conversion (P0.3)
        ADCON0 |= 0x44; // enable ADC
        ADMODA = 0x10;  // single conversion mode
        ADMODB = 0x00;  // no 4 conv. int. mode, no boundary, clk divider = 1
//      EA = 1;         // Enable all interrupts
        btADComp = 0;   // clear
        while(1)                // main loop
                ADCON0 |= 0x01; // Immediate start
                while (btADComp == 0);  // wait until done
                P2 = AD0DAT2R;  // copy LSB result to Port 2 (LEDs)
                btADComp = 0;   // clear it
void adc_isr (void) interrupt 14 using 1
        if (ADCON0 & 0x08) {
                ADCON0 &= ~0x08;    // clear ADCI0 flag
                btADComp = 1;   // set our flag
Even Code Architect states to enable EA after init, although it's not in its code. Why would setting EA cause it to stop working?
0
