Latches
Hi all
I need help from you
in my project i have to display the voltage
on seven segment display.
iam using 89c51 & keil software
I connected 3 number seven segment displays to the PORT2 by using 74LS373 latches .
Latch enable signals were giveing from PORT3.
iam using this code
sbit c1=P3^0;
sbit c2=P3^1;
sbit c3=P3^2;
s1,s2,s3=data /*voltage=4.57v*/
while(1)
P2=s1; /*P2=4*/
c1=1; /* Latch enable*/
Delay(100);
c1=0; /* Latch disable*/
P2=s2; /*P2=5*/
c2=1;
Delay(100);
c2=0;
P2=s3; /*P2=7*/
c3=1;
Delay(100);
c3=0;
In the first loop it is showing correct values but in the second time loop it showing
interchanged values on the display.
Iam using ADC804+89c51+74LS373(3 numbers)
+7 seven segment displays(3 numbers)
thank you
regards
nari
