Helo, Some times that I "Rebuild all target files" I get a strange error for which I couldn't find any reasons.Surprisingly it is automatically resolved on the succeeding "Rebuild all target files" command without any intermediate action being done.
Build target 'LCP2148' compiling main.c... main.c Error: C3397E: System clock has been set back Target not created
I have also seen exactly the same error message (above) but with a diferent error code Q0589E this time:
Build target 'LCP2148' compiling main.c... main.c Error: Q0589E: System clock has been set back Target not created
Do you have a licensed version or is this a Eval Version of the tools?
Thanks for your reply, I have a licensed version.
This was a problem of MDK-ARM V2.50 but it should no longer occur with Version 3.00. Did you download an upgrade?
No I didn't download an upgrade but my version is up to date (I think) I have just purchased and use uVision3 V3.30a of RVMDK-ARM Also the Help->Check for update option of the environment says that "No updates are available for your product" Thanks
Ali, sorry it was my mistake. The problem is already solved and will be covered in the version that will become available next week. Sorry for the confusion. Reinhard
