With the latest Keil ARM tool (uVision 3.31, RealView compiler), the Linker tab in my project options keeps specifying a default scatter file (named after my project). When I build, the linker complains about the missing scatter file. When I delete this filename from the Linker tab and then close the options dialog, I can build. However, as soon as I reenter the Linker tab, this non-existent scatter file appears again. How do I stop uVision from doing this? Is this a bug?
Yes, this is a wrong behaviour in the Eval Mode. If you need a fix for it send email to support.intl@keil.com Reinhard
