Hi, I'm using the P89LPC932A1 and attempting to read the global checksum using IAP during normal program execution. I have used this knowledgebase article as my guide: http://www.keil.com/support/docs/2554.htm So basically, I added this function to my code:
long unsigned IAP_ReadGlobalCRC (void) { ACC = 6; // MOV A,#06H return ((unsigned char (code *)(void)) 0xFF03)(); // LJMP 0FF03H }
Thank you for replying to my thread. I think I might be "seeing the light". Below, I have posted what this compiles to. Basically it seems that after LCALL FF03, the 32-bit result should be in R4-R7 with the MSB being in R4. But this code looks like it overwrites R4-R6 with 00's and then leaves R7 as is. This would explain why I get 0x000000XX as the return value. However, I'm a bit confused by this c code to begin with. First, why would Keil say that this is the way to do it when the compiler generates code that overwrites the true result. How *should* this be done using c? Much Thanks Philip This is what it compiles to in my project:
; FUNCTION IAP_ReadGlobalCRC (BEGIN) ; SOURCE LINE # 80 ; SOURCE LINE # 81 ; SOURCE LINE # 82 0000 7406 MOV A,#06H ; SOURCE LINE # 84 0002 12FF03 LCALL 0FF03H 0005 E4 CLR A 0006 FC MOV R4,A 0007 FD MOV R5,A 0008 FE MOV R6,A ; SOURCE LINE # 85 0009 ?C0007: 0009 22 RET ; FUNCTION IAP_ReadGlobalCRC (END)
Ouch. Didn't spot this. I think this knowledgebase article has a typo:
long unsigned IAP_ReadGlobalCRC (void) should be unsigned long IAP_ReadGlobalCRC (void)
; FUNCTION IAP_ReadGlobalCRC (BEGIN) ; SOURCE LINE # 80 ; SOURCE LINE # 81 ; SOURCE LINE # 82 0000 7406 MOV A,#06H ; SOURCE LINE # 83 0002 12FF03 LCALL 0FF03H ; SOURCE LINE # 84 0005 ?C0007: 0005 22 RET ; FUNCTION IAP_ReadGlobalCRC (END)
