This is slightly off topic... it's about the ATMEL chip, not the KEIL tools. Can anyone confirm that the CPOL bit is not properly documented in the current datasheet? It's called "channel polarity", but it does not appear to invert the PWM signal, unless the duty cycle is either 0% or 100%.
