Hi all , I am using the Easyweb example program provided in Keil uvision3 for phytec board under c:\Keil\ARM\Boards\Phytec\LPC229x\. I tried to download the program to the flash memory in the board...the program got donwloaded ...when i run the program i am getting an error as below
Memory mismatch address: 0x80000000 Value=0x00 Expected =0x18
Hello all, This is the ini file that I am using it to download the program to the onchip flash memory. Is there any problem in the ini file? t.senthil
/***********************************************************************/ /* This file is part of the ARM Compiler package */ /* Copyright KEIL ELEKTRONIK GmbH 1992-2004 */ /***********************************************************************/ /* */ /* FLASH.INI: Flash Initialization File */ /* */ /***********************************************************************/ //*** <<< Use Configuration Wizard in Context Menu >>> *** FUNC void Setup (void) { // <h> External Memory Controller (EMC) // <h> Bank Configuration 0 (BCFG0) // <o1.0..3> IDCY: Idle Cycles <0-15> // <o1.5..9> WST1: Wait States 1 <0-31> // <o1.11..15> WST2: Wait States 2 <0-31> // <o1.10> RBLE: Read Byte Lane Enable // <o1.26> WP: Write Protect // <o1.27> BM: Burst ROM // <o1.28..29> MW: Memory Width <0=> 8-bit <1=> 16-bit // <2=> 32-bit <3=> Reserved // </h> _WDWORD(0xFFE00000, 0x20003CE3); // BCFG0: Flash Bus Configuration _WDWORD(0xE002C014, 0x0E6001E4); // PINSEL2: CS0, OE, WE, BLS0..3 // D0..31, A2..23, JTAG // </h> } Setup(); // Setup for Flash
