Cant get to UART1 interrupt on F067
I used the SI Labs config 2 wizard to generate the following code and then added the interrupt at the bottom. The only thing I do in my main is try to set TI1 to 1 which should signal hardware to jump to the UART1 ISR. If I set a break point in main and in the UART1 ISR, I never get there. Any ideas???
Jeff
Below is code:
#include "c8051F060.h"
void Timer_Init();
void UART_Init();
void Port_IO_Init();
void Oscillator_Init();
void Interrupts_Init();
void Init_Device(void);
void UART1_ISR();
void main();
void Reset_Sources_Init();
void UART1_ISR(void);
void main()
TI1 = 1;
// Peripheral specific initialization functions,
// Called from the Init_Device() function
WDTCN = 0xDE;
WDTCN = 0xAD;
void Timer_Init()
SFRPAGE = TIMER01_PAGE;
TCON = 0x40;
TMOD = 0x20;
CKCON = 0x10;
TH1 = 0x40;
void UART_Init()
SFRPAGE = UART1_PAGE;
SCON1 = 0x50;
void Port_IO_Init()
// P0.0 - TX1 (UART1), Open-Drain, Digital
// P0.1 - RX1 (UART1), Open-Drain, Digital
// P0.2 - Unassigned, Open-Drain, Digital
// P0.3 - Unassigned, Open-Drain, Digital
// P0.4 - Unassigned, Open-Drain, Digital
// P0.5 - Unassigned, Open-Drain, Digital
// P0.6 - Unassigned, Open-Drain, Digital
// P0.7 - Unassigned, Open-Drain, Digital
// P1.0 - Unassigned, Open-Drain, Digital
// P1.1 - Unassigned, Open-Drain, Digital
// P1.2 - Unassigned, Open-Drain, Digital
// P1.3 - Unassigned, Open-Drain, Digital
// P1.4 - Unassigned, Open-Drain, Digital
// P1.5 - Unassigned, Open-Drain, Digital
// P1.6 - Unassigned, Open-Drain, Digital
// P1.7 - Unassigned, Open-Drain, Digital
// P2.0 - Unassigned, Open-Drain, Digital
// P2.1 - Unassigned, Open-Drain, Digital
// P2.2 - Unassigned, Open-Drain, Digital
// P2.3 - Unassigned, Open-Drain, Digital
// P2.4 - Unassigned, Open-Drain, Digital
// P2.5 - Unassigned, Open-Drain, Digital
// P2.6 - Unassigned, Open-Drain, Digital
// P2.7 - Unassigned, Open-Drain, Digital
SFRPAGE = CONFIG_PAGE;
XBR2 = 0x44;
int i = 0;
OSCXCN = 0x67;
for (i = 0; i < 3000; i++); // Wait 1ms for initialization
while ((OSCXCN & 0x80) == 0);
CLKSEL = 0x01;
OSCICN = 0x00;
IE = 0x80;
EIE2 = 0x40;
// Initialization function for device,
// Call Init_Device() from your main program
Timer_Init();
UART_Init();
Port_IO_Init();
Oscillator_Init();
Interrupts_Init();
// UART1 Interrupt Service Routine
void UART1_ISR (void) interrupt 20
TI1 = 0;
// Clear interrupt flag
  • Sorry forgot, add the Init_device(); in main. Still does not jump tho.
  • It looks like Tx should be push-pull not open drain
  • Thanks everyone for you help. I now have it working and have posted below the code that will jump in the UART1 ISR for anyone that would like to use it as a bare minimum check. My settings are for a Ex. Osc. at 22.1184 Mhz and a baud rate of 57600
    // Generated Initialization File //
    void Timer_Init();
    void UART_Init();
    void main()
    Init_Device();
    TI1 = 1;
        WDTCN     = 0xDE;
        WDTCN     = 0xAD;
    void Timer_Init()
        TCON      = 0x40;
        TMOD      = 0x20;
        CKCON     = 0x10;
        TH1       = 0x40;
    void UART_Init()
        SCON1     = 0x50;
    void Port_IO_Init()
        XBR2      = 0x44;
        int i = 0;
        OSCXCN    = 0x67;
        CLKSEL    = 0x01;
        OSCICN    = 0x00;
        IE        = 0x80;
        EIE2      = 0x40;
    	Timer_Init();
        UART_Init();
        Port_IO_Init();
        Oscillator_Init();
        Interrupts_Init();
    	SFRPAGE = UART1_PAGE;  //Return to page 1
      TI1 	= 0;
