The keil sofeware give too few example about AT91SAM7S64. The development of AT91SAM7S64 is not easy just like LPC22XX. If, post to godday@21cn.com. Thanks a lot!
The following should help: - in the product: Keil\ARM\Boards\Atmel\AT91SAM7S - http://www.keil.com/appnotes/docs/apnt_190.asp
"The keil sofeware give too few example about AT91SAM7S64" Have you looked on Atmel's site?
Well, maybe I should say the example of LPC22XX help me much. I can easily master how to use the chip because the example of LPC22XX is exhaustive. You know, each peripheral has its example. But in the case of AT91SAM7S64, the example is pool correspondingly to the LPC example. If Keil can provide more example of AT91SAM7S64, that will help much.
