Setting more than one environemnt variables in Configure SVCS
I'm trying to set more than one environment variable in the Environment field under the SVCS...Configure Version Control... dialog box. No matter what I try, it doesn't seem to work. Tried setting one in this field and the other in Control Panel, but that didn't work either. As far as I can tell, each needs to be set in this field to work properly, but I cant set them *both* at the same time. (They are PATH and VCSDir environment variables.)
Is it possible to set more than one environment variable in this field?
p.s. Trying to interface uVision 2.31 to PVCS 7.5 using command line via this menu. If this question is answered, I think I have it.
