TEA encryption with 128bit key
If anyone needs some basic encryption in software, here's one solution. This TEA implementation fits within less than 700 bytes. It's based on original TEA. P89LPC901 needs 300ms for 32 iterations. Compiled with "OPTIMIZE (9,SIZE)".
#define _DELTA    0x9E3779B9
#define _ITER	  32	/* _ITER = the number of iterations.*/
			/* 32 is ample, 16 is sufficient,   */
			/* as few as eight should be OK. 	*/
#define _SUM   	  0xC6EF3720
/* Global variables for encryption                                  */
unsigned long int v0,v1;	/* encrypted/decrypted data	*/
volatile unsigned long int code
	k0=0x1234aaaa, 	/* 128 bit key				*/
	k1=0x5678bbbb,	/* hard coded in internal   		*/
	k2=0x9abc4321,	/* flash memory				*/
	k3=0xdef0ffff;	/* Same key used by host    		*/
/* TEA : The Tiny Encryption Algorithm (TEA)			    */
/*       ba David Wheeler and Roger Needham at the Computer 	    */
/*		 Laboratory of Cambridge University		    */
/*       More info: http://www.simonshepherd.supanet.com/tea.htm    */
/* TEA_decipher - decryption procedure                              */
/*                uses global variables                             */
/* Source ported to Keil C51 by Marko Pavlin  			    */
void TEA_decipher(void)
 unsigned long int sum=_SUM, delta=_DELTA;
 unsigned char n = _ITER;
   while(n-->0)
      v1 -= (v0 << 4)+k2 ^ v0+sum ^ (v0 >> 5)+k3;
      v0 -= (v1 << 4)+k0 ^ v1+sum ^ (v1 >> 5)+k1;
      sum -= delta;
/* TEA_encipher - encryption procedure                              */
void TEA_encipher(void)
   unsigned long int sum=0,delta=_DELTA;
   unsigned char n=_ITER;
   while(n-->0)
      sum += delta;
      v0 += (v1 << 4)+k0 ^ v1+sum ^ (v1 >> 5)+k1;
      v1 += (v0 << 4)+k2 ^ v0+sum ^ (v0 >> 5)+k3;
Variables are global. If there's enough memory available, use pointer parameters for key and data (adds about 400 bytes for pointer opertions).
Works with 16 bit (unsigned int), too. In this case replace constants with:
#define _SUM   	  0xC6EF
But key in this case is only 64bit.
M.
  • hi
    i saw the source code written for Tea Encryption.
    Sir, now i am working on a project called Automatic Frost controller for Refrigerators Using P89LPC901.
    Now, That i am new to this IC and the data provided in the data sheet is not sufficient can you tell me some thing about usage of this IC and Can you send me some Source Codes to configure the ports .
    Looking forward for your Response
    -Srinivas
    Triphase Tech
  • Hello Marko,
    Thanks for giving us TEA :-)
    I've been coding SHA-1, SHA-256, DSA and AES for a little ARM project. The SHAs work fine but I haven't managed to acheive the DSA signing part yet.
    Would I be right in saying TEA is based on the DES encryption? Does this TEA implementation have just one key? I need a private and several public keys for my project...?
    Best regards,
    Malcom
  • It's single key. I used it for simple encrypted rx/tx in one project.
