hi, Does anyone know a way to obtain last versions of Keil On-Line manuals placed at http://www.keil.com/support/man/ for off-line reading in .pdf or .chm format? For example, http://www.keil.com/support/man/docs/a51/ says that: Revision History May 2004: Initial revision in CHM format. Where this CHM version may be downloaded from? Thanks, Oleg
When you download the product (including the evaluation), all the PDF manuals are included.
Not only the PDF-Manuals are installed, but also the Compiled HTML version. The newest manuals are in chm.
"Not only the PDF-Manuals are installed, but also the Compiled HTML version. The newest manuals are in chm." Are you sure? I have v7.50, and the compiler & assembler manuals ("User Guides") are PDF only; the C51 library online help is, and always has been, CHM. Also the errors help is CHM.
You maybe also need to install the uVision3 for C51 Beta.
