Hi i've just switched from assembly language to c and i've studied a little about RTX51 Real time operating system but i could'nt figure out its purpose for microcontroller applications. Can any one kindly make me understand with examples what difference RTX51 makes and a little tutorial about it.Thanks In Advance For your help
Hi i've just switched from assembly language to c and i've studied a little about RTX51 Real time operating system but i could'nt figure out its purpose for microcontroller applications You are trying to jump too far. Forget about RTX till you get comfortable with C. Erik
You might find this article interesting. http://www.embedded.com/2000/0009/0009feat4.htm
I take offense from the statement in the article "many embedded systems survive perfectly well without a multitasking real-time operating system (RTOS)." correctly it should read "many embedded systems excel without a multitasking real-time operating system (RTOS)" otherwise the article seems fair Erik
Hi, Actually i want to figure out the edges that an RTOS and c programming has got over simple assembly language. Any body so nice and helpful willing to help me plz help
In some ways, and RTOS for a '51 is like a cheap condom: It tends to give you a false sense of security while you're getting screwed.
"Actually i want to figure out the edges that an RTOS and c programming has got over simple assembly language" An RTOS has nothing specifically to do with 'C' programming. See this thread on the pros & cons of 'C' and assembler: http://www.8052.com/forum/read.phtml?id=82834 Generally, an RTOS is unnecessary for anything suited to run on an 8051 - irrespective of what programming language you use.
In some ways, and RTOS for a '51 is like a cheap condom: It tends to give you a false sense of security while you're getting screwed. BINGO, I wish I had come up with that one. Erik
