Hello, is it possible to see how much memory is still avaible. I have NDATA(0xC000 - 0xE7FF) and a program. Now I would add a data array but I should know what the memory size is still avaible. I've tried to use the memory window, but it works only with code area and doesn't work if I write the Address 0xC000!(I see only zeros) Thanks for any input, with best regards, A
http://www.keil.com/support/man/docs/l166/l166_in_listing.htm
