I know you have many discussions about warning L16 but I couldn't find one that would match with my problem below. I got a warning L16: uncalled segment - SEGMENT: ?PR?API_module2?MODULE2 which my app had nothing to do with. See code below:
in test.c: ---> app code built with lib1.lib main { api_module1(); } in module1.c: ----> part of lib1.lib volatile char var1 api_module1( void ) { var1 = ... } in module2.c: ----> part of lib1.lib extern volatile char var1 api_module2 ( void ) { if (var1 == ...) }
"I got a warning L16: uncalled segment - SEGMENT: ?PR?API_module2?MODULE2 which my app had nothing to do with." What do you mean by that? If your application has nothing to do with it, why is it in your Project? If it's in your project but never used, then you will obviously get an "uncalled segment" warning - because it is not called!
Sorry for being unclear. What I meant is my app linked to a library called lib1.lib. Lib1.lib was built with two .c files called module1.c and module2.c. My app only used the function defined in module1.c and nothing in module2.c. There is one variable I found that is used between these two c files. The warnings were for the functions defined in module2.c which my app does not call. I can't simply get rid of this variable because my other apps used module1 and module2 extensively.
It was the way I described originally. Nevertheless, I appreciate your advice about moving the global variable to a common file. I fixed it and still got this unwanted warning so it must be something else. I have to continue searching for the culprit. Thank you very much for your help!
Have you looked in the map file to see what modules are included from the library (and why)? Jon
I created a simple project and linked it and I do not get the same problem you do. Here is the linker MAP file.
BL51 BANKED LINKER/LOCATER V5.03 BL51 BANKED LINKER/LOCATER V5.03, INVOKED BY: C:\KEIL\C51\BIN\BL51.EXE main.obj, .\libprj.LIB TO codeprj RAMSIZE (256) MEMORY MODEL: SMALL INPUT MODULES INCLUDED: main.obj (MAIN) .\libprj.LIB (FUNC1) C:\KEIL\C51\LIB\C51S.LIB (?C_STARTUP) LINK MAP OF MODULE: codeprj (MAIN) TYPE BASE LENGTH RELOCATION SEGMENT NAME ----------------------------------------------------- * * * * * * * D A T A M E M O R Y * * * * * * * REG 0000H 0008H ABSOLUTE "REG BANK 0" DATA 0008H 0001H UNIT ?DT?FUNC1 IDATA 0009H 0001H UNIT ?STACK * * * * * * * C O D E M E M O R Y * * * * * * * CODE 0000H 0003H ABSOLUTE CODE 0003H 000CH UNIT ?C_C51STARTUP CODE 000FH 0005H UNIT ?PR?MAIN?MAIN CODE 0014H 0004H UNIT ?PR?FUNC1?FUNC1 OVERLAY MAP OF MODULE: codeprj (MAIN) SEGMENT +--> CALLED SEGMENT --------------------- ?C_C51STARTUP +--> ?PR?MAIN?MAIN ?PR?MAIN?MAIN +--> ?PR?FUNC1?FUNC1 SYMBOL TABLE OF MODULE: codeprj (MAIN) VALUE TYPE NAME ---------------------------------- ------- MODULE MAIN C:0000H SYMBOL _ICE_DUMMY_ C:000FH PUBLIC main ------- PROC MAIN C:000FH LINE# 3 C:000FH LINE# 4 C:000FH LINE# 5 C:0012H LINE# 7 ------- ENDPROC MAIN ------- ENDMOD MAIN ------- MODULE FUNC1 C:0000H SYMBOL _ICE_DUMMY_ D:0008H PUBLIC libvar C:0014H PUBLIC func1 ------- PROC FUNC1 C:0014H LINE# 3 C:0014H LINE# 4 C:0014H LINE# 5 C:0017H LINE# 6 ------- ENDPROC FUNC1 ------- ENDMOD FUNC1 Program Size: data=10.0 xdata=0 code=24 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
Hi Jon, Thanks for the responses. Yes, the app's map file showed the functions in module2. The 'Why' is what I'm looking for.
You may want to start by looking in the call tree in the MAP file:
Hello Jon, I rebuilt with 'Cross Reference' option and the map file is much more clear to read. As you pointed it out, I found the culprit. I found the ?PR?MODULE2 under a ?CO? of another/init module name, which is used by the app. It looks like I have a lot of cleaning up work to do but at least I know where to look now. THank you so much for your help.
Just out of curiosity: In uVision2, when bringing up 'options for library lib1.lib', the menu will show a list of 'Select module to always include' module (all .c files) available to the application from this lib1.lib. I'm wondering if there is such option to select 'Always exclude' module.
