Using the Keil LPC 2129 EVB, I set up the I2C port in Slave Mode and talk to a master device on the bus. I notice that every 500 or so transfers, when the Keil EVB recieves: [SLA][W] it Nacks the byte instead of Acking it. I don't understand how it could be Nacking, since when it recieves its Slave Address and Write bit, it goes into a case where I only ACK. An excerpt of my code is as follows:
void i2c_isr(void) __irq { unsigned char status; status = I2STAT & 0xF8; switch(status) { // SLA+W has been recieved and ACK has been returned //Arbitration Lost in SLA+R/W as //Arbitration Lost in SLA+R/W case 0x60: case 0x68: case 0x70: case 0x78: I2CONCLR = 0x20; //STA=0 I2CONSET = 0x44; //Set ACK to enable Slave Rx Mode I2CONCLR = 0x08; // SI = 0 break; ...
