Hello, I'm using a C167CS-L40M on a PhyCore 167HSE from Phytec. My problem is : how can i use the uart communication. Thanks a lot
Does C166 not come with any examples? Does your PhyCore 167HSE not come with any examples?
No, I don't find any example for UART utilisation
What about the HELLO example? Jon
"No, I don't find any example for UART utilisation" Did you actually look?? On the Phytec support site, I see: "Standard PHYTEC demo programs included in Rapid Development Kits - 'hello' and 'blinky' - can be downloaded from the tables below. These demo programs are intended to ... provide 'out-of-the-box' examples - including source code, header files and proper compiler and other tool configuration settings - as a guide to starting your own project with Keil..." http://www.phytec.com/support/demodownloads.htm If that doesn't include configuring the UART, you should complain to Phytec!
