Hi! I have a problem with global xdata variables. In main.c I have the following code to make two global arrays.
unsigned int xdata fordonsnummer[100] _at_ 0x000; unsigned int xdata tomvikt[100] _at_ 0x0c8;
extern unsigned int xdata fordonsnummer[]; extern unsigned int xdata tomvikt[];
"... in some heather files ..." Are they the lucky ones...? ;-) "I have marked the "Use the onchip XRAM" in Options for target." That option simply provides information to the tools; it's just a shortcut way of telling the linker how much XDATA memory you have, and at what address range. What it does not do is to set up any configuration registers, etc, that may be required on your target hardware to enable the physical memory. You will need to read the manual(s) and/or datasheet(s) for your particular hardware for further details.
hi, One function writes a value to a position in the array but when another reads the same value something goes wrong. Try to use volatile keyword:
unsigned int volatile xdata fordonsnummer[100] _at_ 0x000; unsigned int volatile xdata tomvikt[100] _at_ 0x0c8;
"One function writes a value to a position in the array but when another reads the same value something goes wrong." Have you tried it in the simlator, to verify that your code really is writing to & reading from the locations you expect...? Have you tried it with the debugger, to verify that your hardware memory locations are actually working properly...?
Hello all! Now it works and the solution was to setup the SFR register to enable the xdata area. I thought this was automatically done by the compilator when I marked the "Use on chip xdata" box in the target dialog. Thank you all for your suggestions I'll keep them in mind. Regards Jonas Finell
"Now it works and the solution was to setup the SFR register to enable the xdata area. I thought this was automatically done by the compilator when I marked the "Use on chip xdata" box in the target dialog." I think that checking the "Use on chip xdata/code" boxes is just a substitute for entering the start address and length of these memory areas. It is a bit misleading in that sense, if I had the choice I'd get rid of those check boxes.
"I think that checking the "Use on chip xdata/code" boxes is just a substitute for entering the start address and length of these memory areas." Yes, it is - see my earlier post. "It is a bit misleading in that sense" I agree. "if I had the choice I'd get rid of those check boxes." Dunno about getting rid of them - they just need a better better name!
