I meant to say... Is there anyway to autoload PPAGE VTREG in the simulator to 0?
What about using a debugger INI file with PPAGE=0 init? Jon
Is there a way to Autoload a .ini file when you enter the debugger?
It's on the 'Debug' tab in the Project options. You have read the uVision Getting Started Guide, haven't you...?
Thanks & Yes
I get an "error 42" when I start the debugger with "PPAGE = 0;" in the .ini file.
Well, test it all on the command line in the debugger to find out where the error comes from. Jon
