I have a problem when I want to generate code from Matlab/Simulink with real time workshop for a model: MIRCOS 167 The following is what Matlab says to me: ### Starting Real-Time Workshop build procedure for model: c166test ### Generating code into build directory: .\c166test_c167_rtw ### Invoking Target Language Compiler on c166test.rtw tlc -r .\c166test_c167_rtw\c166test.rtw 'd:\MATLAB6p5p1\work\c167.tlc' -O.\c166test_c167_rtw '-Id:\MATLAB6p5p1\work' '-ID:\MATLAB6p5P1\rtw\c\tlc\mw' '-ID:\MATLAB6p5P1\rtw\c\tlc\lib' '-ID:\MATLAB6p5P1\rtw\c\tlc\blocks' '-ID:\MATLAB6p5P1\rtw\c\tlc\fixpt' -aEnforceIntegerDowncast=1 -aFoldNonRolledExpr=1 -aForceParamTrailComments=0 -aGenerateComments=1 -aGenerateReport=0 -aIncDataTypeInIds=0 -aIncHierarchyInIds=0 -aInlineInvariantSignals=0 -aInlineParameters=0 -aInlinedPrmAccess="Literals" -aLocalBlockOutputs=1 -aMaxRTWIdLen=31 -aMem_Mod="Compact" -aPrefixModelToSubsysFcnNames=1 -aRTWVerbose=1 -aRollThreshold=5 -aShowEliminatedStatements=0 -aTiming=0 -aReleaseVersion=13.1 -p10000 ### Loading TMW TLC function libraries ... ### Initial pass through model to cache user defined code ### Caching model source code .... ### Writing source file c166test.c ### Writing header file c166test.h ### Writing header file c166test_types.h . ### Writing header file c166test_private.h ### Writing source file c166test_data.c ### TLC code generation complete. ### c166test.mk which is generated from D:\MATLAB6p5P1\toolbox\c167\bin\c167.tmf is up to date ### Wrapping unrecognized make command (angle brackets added) ### <D:\MATLAB6p5P1\toolbox\c167\bin\gmake.exe> ### in default batch file ### Building c166test: .\c166test.bat d:\MATLAB6p5p1\work\c166test_c167_rtw>set MATLAB=D:\MATLAB6p5P1 d:\MATLAB6p5p1\work\c166test_c167_rtw>D:\MATLAB6p5P1\toolbox\c167\bin\gmake.exe -f c166test.mk ADD_MDL_NAME_TO_GLOBALS=1 BEFORE .c.obj (c166test.c) Compiling (g166-cc1): c166test.c D:\Keil\C166\bin\c166 @D:\MATLAB6p5P1\work\c166test_c167_rtw\c166test.cmd C166 COMPILER V4.25 - SN: K6DZP-W4YZ5E COPYRIGHT KEIL ELEKTRONIK GmbH 1991 - 2003 *** WARNING C138 IN LINE 57 OF C166TEST.C: expression with possibly no effect *** WARNING C138 IN LINE 86 OF C166TEST.C: expression with possibly no effect C166 COMPILATION COMPLETE. 2 WARNING(S), 0 ERROR(S) D:\MATLAB6p5P1\toolbox\c167\bin\gmake.exe: [c166test.obj] Error 1 (ignored) .c.obj (c166test_data.c) Compiling (g166-cc1): c166test_data.c D:\Keil\C166\bin\c166 @D:\MATLAB6p5P1\work\c166test_c167_rtw\c166test_data.cmd C166 COMPILER V4.25 - SN: K6DZP-W4YZ5E COPYRIGHT KEIL ELEKTRONIK GmbH 1991 - 2003 C166 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S) {D:\MATLAB6p5P1/rtw/c/libsrc/} (rt_logging) Compiling (g166-cc1): rt_logging D:\Keil\C166\bin\c166 @D:\MATLAB6p5P1\work\c166test_c167_rtw\rt_logging.cmd C166 COMPILER V4.25 - SN: K6DZP-W4YZ5E COPYRIGHT KEIL ELEKTRONIK GmbH 1991 - 2003 *** WARNING C192 IN LINE 774 OF D:\MATLAB6P5P1/RTW/C/LIBSRC/RT_LOGGING.C: 'parameter 3': value truncated *** WARNING C192 IN LINE 783 OF D:\MATLAB6P5P1/RTW/C/LIBSRC/RT_LOGGING.C: 'parameter 3': value truncated *** WARNING C192 IN LINE 790 OF D:\MATLAB6P5P1/RTW/C/LIBSRC/RT_LOGGING.C: 'parameter 3': value truncated *** WARNING C192 IN LINE 821 OF D:\MATLAB6P5P1/RTW/C/LIBSRC/RT_LOGGING.C: '=': value truncated *** ERROR C67 IN LINE 1049 OF D:\MATLAB6P5P1/RTW/C/LIBSRC/RT_LOGGING.C: 'real64_T': undefined identifier C166 COMPILATION COMPLETE. 4 WARNING(S), 1 ERROR(S) D:\MATLAB6p5P1\toolbox\c167\bin\gmake.exe: [rt_logging.o] Error 2 (ignored) Creating or updating the real-time library... (compact memory model) D:\Keil\C166\bin\lib166 CREATE D:\MATLAB6p5P1\toolbox\c167\rtc167\LIBRTC167_C.LIB LIB166 LIBRARY MANAGER V4.24 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 D:\Keil\C166\bin\lib166 ADD D:\MATLAB6p5P1\toolbox\c167/rtc167/c/rt_nrand.o, D:\MATLAB6p5P1\toolbox\c167/rtc167/c/rt_urand.o, D:\MATLAB6p5P1\toolbox\c167/rtc167/rt_dummy.o TO D:\MATLAB6p5P1\toolbox\c167\rtc167\LIBRTC167_C.LIB LIB166 LIBRARY MANAGER V4.24 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 D:\Keil\C166\bin\lib166 ADD D:\MATLAB6p5P1\toolbox\c167/rtc167/c/rt_atan2.o, D:\MATLAB6p5P1\toolbox\c167/rtc167/c/rt_atan232.o, ............................... D:\MATLAB6p5P1\toolbox\c167/rtc167/rt_dummy2.o TO D:\MATLAB6p5P1\toolbox\c167\rtc167\LIBRTC167_C.LIB LIB166 LIBRARY MANAGER V4.24 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 *** ERROR 224: ATTEMPT TO ADD DUPLICATE MODULE FILE: D:\MATLAB6P5P1\TOOLBOX\C167/RTC167/C/RT_FORWARDSUBCC_SGL.O MODULE: MATLAB6P5P1_RTW_C_LIBSRC_RT_FORWARDSUBCC_ D:\MATLAB6p5P1\toolbox\c167\bin\gmake.exe: *** [LIBRTC167_C.LIB] Error 3
I have refered to the LIB166 User's Guide, " Summary *** Error 224 ATTEMPT TO ADD DUPLICATE MODULE MODULE: filename (modulename) Description The specified modulename already exists in the library file and cannot be added. " But I still don't know how to sovle the problem!
You need to rename the filename, since the compiler uses the filename to derrive the module name.
"Description 'The specified modulename already exists in the library file and cannot be added.' But I still don't know how to sovle the problem!" Do not try to add a module to a library when that library already contains a module with the same name!
