Hi, I have a problem of displaying the output data on LCD. it will display "NaN", which i have read that this is not a data. This problem arises when i start to acquire data from the sensors (meaning when there is reading). But if the sensors circuit are off and the reading is zero, there is output data. i think it could be due to integer to floating point conversion of the aquired data. i have tried several times by changing the data types but the output is still display :NaN. But if i do normalize the data in (1 to -1)there will be an output reading. If i dont normalize the data, the output reading will be in around 1000 to 8000 . The problem arises when i am not normalizing the data.The acquired data is CH[j]. Here is the code.
#include <stdio.h> #include <math.h> #include <reg51.h> //#include <AT89X52.h> #include <stdlib.h> //#include <intrins.h> ....... /*Declare External Function*/ extern void ANN(int n,float CHn[]); /*Main Program*/ main() { int pmax=10,i,n=8,j; int data_LSB,data_MSB,CH[10]; float CHn[10],min=2,max=1; ppi_set(); serial_init(); for (i=0;i<=pmax;i++) //for number of pulse <=10 { if (PULSE==1) //Check whether PULSE =1 { for (j=0;j<8;j++) //If yes do DAQ of 8 Ch (0-7) { P1=j; //Write Add to Port 1 (0-7) data_LSB=PA; //Read LSB data from Port A data_MSB=PB; //Read MSB data from Port B CH[j]=(data_MSB<<8)|data_LSB; //Shift Left MSB data 8 times ("|"is bitwise 'or' to sum both bit) printf("%d\t",CH[j]); // min=(min<CH[j])? min:CH[j]; //Scan for Min data // max=(max>CH[j])? max:CH[j]; //Scan for Max data } printf("\n"); for (j=0;j<n;j++) { // CHn[j]=2*((CH[j]-min)/(max-min))-1; //Data Normalization formula make data in range (-1,1) CHn[j]=(float) CH[j]; //Raw data (in range 1000-8000) } ANN(n,CHn); //Call ANN process function } wait(1); } } /*ANN PROCESS*/ #include <stdio.h> #include <math.h> #include <intrins.h> /* External LCD output function*/ extern void LCD(float O[]); /*ANN Function Definitioan*/ void ANN(int n,float CHn[]) { int j,h,hmax=6,o,omax=4; //Hidden Neuron (hmax)=6, Output Neuron(omax)=4 float xdata O[5],H[8]; float xdata WHI[6][8]= {//WHI=Weight value of connection between Input=8 and Hidden=6 /*Weight with logsig and logsig transfunction*/ {2.7294,4.5239,-0.0103,-0.6089,4.8868,-5.7313,-2.6335,0.4967}, {-4.7325,-3.8315,-0.1689,-1.6844,8.3110,4.7062,0.1422,-1.3525}, {3.1464,2.3160,0.6550,0.6286,3.3174,0.9235,8.5057,0.6745}, {2.6970,-3.2395,-0.7225,-4.6076,5.4900,-7.1220,0.5794,2.2767}, {4.4916,1.7946,0.4944,0.5825,0.7911,-9.6612,-4.7229,-0.1789}, {1.6326,-4.5621,-4.2867,-0.9461,-2.9762,-3.0127,-0.6397,-1.7811} }; float xdata WOH[4][6]= {//WOH=Weight value of connection between Hidden=6 and Output=4 /*Weight with logsig and logsig transfunction*/ {10.2251,3.9513,2.6186,8.5117,3.7212,-7.4772}, {-5.0325,-9.1396,-1.4935,13.1217,-0.5011,5.5292}, {4.3388,-13.4855,3.0468,-10.0947,6.0913,-8.8211}, {-9.7137,9.8602,-1.9421,-2.2828,-8.7116,1.1900} }; float xdata BH[6]={//BH=Bias of Hidden Neuron=6 /* Bias with logsig and logsig transfunction*/ {-6.4229},{10.9651},{-3.3755},{-2.2552},{-6.6035},{-2.6723}}; float xdata BO[4]={//BO=Bias of Output Neuron=4 /* Bias with logsig and logsig transfunction*/ {-15.1368},{-8.9549},{3.7160},{-0.3211}}; for (h=0;h<hmax;h++)//Multiply and Accumulate Input*Weight(WHI) { H[h]=0; for(j=0;j<n;j++) { H[h]=H[h]+(CHn[j]*WHI[h][j]); // do the Multiply for hidden first } H[h]=H[h]+BH[h]; //Accumulate with Bias of each Hidden H[h]=1.0/(1.0+exp(-1.0*(H[h])));//Logsig Transfer Function } for (o=0;o<omax;o++)//Multiply and Accumulate Hidden Output*Weight(WOH) { O[o]=0; for(h=0;h<hmax;h++) { O[o]=O[o]+(H[h]*WOH[o][h]); //Multiply for output neuron } O[o]=O[o]+BO[o]; // Accumulate with Bias of each Output neuron O[o]=1.0/(1.0+exp(-1.0*(O[o])));//Transfer function logsig } LCD(O); // Call LCD Gas output display function } /* LCD output display of detected gas*/ /* Display Result of Neuron Output using sprintf()*/ /**************************************************************************************/ .... /* Main Program Function : LCD DISPLAY*/ void LCD(float O[]) { //data int i; char buf[40]; ppi_set();//Configures the PPI :PA & PB as input, PC as Output LCD_init (); /* Check on each neuron Output value, if>0.9 display the detected GAS*/ sprintf(buf,"O[0]:%f",O[0]); LCD_StringCentered (1,buf); // sprintf(buf,"O[1]:%f",O[1]); // LCD_StringCentered (2,buf1); wait(30000); } Please help to find out why it keep displaying NaN. Your help is much appreciated. Thanks
