Is it true that some programmers require the hex file records to be arranged in ascending order according to their addresses? I faced a problem with a programmer, the software stopped writing to the chip at a certain line and gave an error. There was no problem with the hex file ( I used a simulator which takes the hex file as input, and it worked properly) Thanx..
