How does inlining work ? static __inline int MULT_16x16R16(int a, int b) { return ( (int)((a * (long)b) >> 16)); } appears to produce the following unexpected snippet... ; FUNCTION MULT_16x16R16 (BEGIN RMASK = @0x6030) ; SOURCE LINE # 1915 ;---- Variable 'b' assigned to Register 'R9' ---- ;---- Variable 'a' assigned to Register 'R8' ---- ; SOURCE LINE # 1917 1442 0B89 MUL R8,R9 1444 F2F50CFE MOV R5,MDH 1448 F2F40EFE MOV R4,MDL 144C F045 MOV R4,R5 ; SOURCE LINE # 1918 144E DB00 RETS ; FUNCTION MULT_16x16R16 (END RMASK = @0x6030)
Take a look at http://www.keil.com/support/man/docs/c166/c166_le_inlinefuncs.htm. Have you simplified how you are calling the inline function? Jon
Needed 1 more simplification to work. Thanks raju ----
