Hello (Mr.Coppi)! Please could You explain how does the OTP reading in monitor mode work? I use the µVision-option 'Keil monitor-166 driver',and than the option 'Phytec KC164 CI' for my board. Is this correct or have I to use another monitor configuration? You wrote I should use segment1-but how can I read the OTP contents when I execute the programm in Segment1,I didn't understand this. Best regards hannes
Hello Hannes, I wrote a new answer in the old thread http://www.keil.com/forum/docs/thread4151.asp
