Class problem
I have a probleme with my memory map.
I have declare external ram between 0x200000-0x400000 , but after compilation i see (.m66) that the space 0x200000-0x200004 is reserve for NDATA0. I don't understand why this class is here and why so small. I just want XDATA0 in external memory
So what can i do for this ?
  • take a look at the HOLD directive. It means, that regardless of the memory model, variables are placed into the NEAR memory, which are smaller than the size defined with the HOLD directive. HOLD has a default value of 6, which means, that integer, char and longint variables are placed into NEAR memory.
