I have updated from version 4.27 to v 5.00. But it seems that I only get an evaluation copy. How can I get the correct version? When I compile I get the following message: ******************************************* * RESTRICTED VERSION WITH 1000H BYTE CODE SIZE LIMIT; USED: 12C2H BYTE (117%) * ******************************************* In uVision it says the correct serial number and end date for support.
We have had this problem with a few customers. Contact technical support and they can help you with this kind of problem. Jon
