Fast 32-bit and 16-bit Division
Here are two assembly language functions which perform division of 32-bit and 16-bit numbers by values in the range 1…16 inclusive.
Although the range of the divisor is very limited, these functions are significantly faster than conventional division functions. The 32-bit division requires about 25% of the time required by C51's 32-bit division and the 16-bit division requires about 60% of the time required by C51's 16-bit division. (Even though the Keil division functions seem to be well optimised.)
The 32-bit division function is sufficiently fast that it may called more than once to divide a 32-bit value by a large value that has convenient factors. For example, dividing by 60 by first dividing by ten and then by six. This will still be significantly faster than conventional division.
The functions also return a remainder and may find useful application in radix conversion by repeated division by the radix.
These functions use the interesting trick of deriving a pointer into the current register bank. This allows the functions to loop through the dividend making the code much more compact although at the slight cost of speed.
    //  fast_int_divide()
    //  This function will divide an unsigned 16-value in registers
    //  R6/R7 by a value in the range 1...16 in register R5. The
    //  function uses the currently selected register bank.
    //  This function requires about 60% of the processing time compared
    //  with the already well optimised Keil compiler unsigned long
    //  divide function and should be much faster than most general
    //  purpose 16-bit by 16-bit divides.
    //  This function also returns the remainder in R4/R5 (R4 will
    //  always be zero.
    #pragma ASM
        $REGUSE _fast_int_divide( R0, R1, R3, R4, R5, R6, R7, A, B )
    #pragma ENDASM
    unsigned int fast_int_divide( unsigned int dividend,
                                  unsigned char divisor ) small
        // dividend in:           R6,R7
        // divisor in:            R5
        // uses:                  R0, R1, R3
        // quotient returned in:  R6,R7
        // remainder returned in: R4,R5
        divisor = divisor;
        #pragma ASM
    ?fast_int_divide:                       ;
            MOV     A,R5                    ;
            JZ      ?tiny_divisor_end       ;if divide by zero: terminate.
            MOV     A,PSW                   ;Get the base address of
            ANL     A,#0x18                 ; the current register bank.
            ORL     A,#0x06                 ;Point to register R6.
            MOV     R0,A                    ;R0 is a pointer to R6.
            MOV     R1,#02                  ;load loop counter.
            MOV     R4,#00                  ;Clear the running remainder.
    ?fast_int_divide_loop:                  ;
            MOV     A,@R0                   ;Get the MS nibble of the dividend
            SWAP    A                       ; into the accumulator.
            ANL     A,#0x0F                 ;
            ORL     A,R4                    ;
            MOV     B,R5                    ;Divide MS nibble by the divisor.
            DIV     AB                      ;
            SWAP    A                       ;Save partial result (which must be in
            MOV     R3,A                    ; the range 0...15) shifted 4 bits.
            MOV     A,B                     ;Save remainder (which must be in
            SWAP    A                       ; the range 0...15) shifted 4 bits left.
            MOV     R4,A                    ;
            MOV     A,@R0                   ;Get next nibble of the dividend
            ANL     A,#0x0F                 ; into the accumulator.
            ORL     A,R4                    ;Or in the remainder from previous
                                            ; partial division.
            MOV     B,R5                    ;Divide by the divisor.
            DIV     AB                      ;
            ORL     A,R3                    ;Or in the previously saved partial result.
            MOV     @R0,A                   ;Save the MSB of the quotient in R6/R7
                                            ; ready to be returned.
            MOV     A,B                     ;Save remainder shifted 4 bits left.
            SWAP    A                       ;
            MOV     R4,A                    ;
            INC     R0                      ;
            DJNZ    R1,?fast_int_divide_loop
            CLR     A                       ;Put remainder in R4/R5
            XCH     A,R4                    ;
            MOV     R5,A                    ;
    ?tiny_divisor_end:                      ;
            RET                             ;
        #pragma ENDASM
        return( dividend );
    //  always be zero.
    #pragma ASM
    #pragma ENDASM
        // divisor in:            R5
        // uses:                  R0, R1, R3
        divisor = divisor;
        #pragma ASM
    ?fast_int_divide:                       ;
            MOV     A,R5                    ;
            ANL     A,#0x0F                 ;
            ORL     A,R4                    ;
            DIV     AB                      ;
            MOV     R4,A                    ;
                                            ; partial division.
            DIV     AB                      ;
            SWAP    A                       ;
            MOV     R4,A                    ;
            INC     R0                      ;
            XCH     A,R4                    ;
            MOV     R5,A                    ;
            RET                             ;
        #pragma ENDASM
        return( dividend );
  • And a test harness:
    extern unsigned int fast_int_divide( unsigned int dividend,
                                         unsigned char divisor ) small;
    extern unsigned long int fast_long_divide( unsigned long int dividend,
    unsigned int compiler_int_divide( unsigned int dividend,
        return( dividend / divisor );
    unsigned int new_int_divide( unsigned int dividend,
        return( fast_int_divide( dividend, divisor ) );
    unsigned long int compiler_long_divide( unsigned long int dividend,
    unsigned long int new_long_divide( unsigned long int dividend,
        return( fast_long_divide( dividend, divisor ) );
    unsigned long int random()
        static unsigned int x;
        x = ( ( 31 * x ) + 123 );
        if( x == 0xFFFF ) x = 0;
        return(x);
    void main( void )
        unsigned int      loop;
        unsigned int      d;
        unsigned int      sd;
        unsigned int      i;
        unsigned long int l;
        unsigned long int lr;
        unsigned char     dummy;
        dummy = 0;
        lr = new_long_divide( new_long_divide(  0x12345678, 6 ), 10 );
        for( loop = 0; loop < 0xFFFF; loop++ )
            i = random();
            d = random();
            if( d == 0 ) d = 1;
            l = ( (unsigned long int)
                  ( random() & 0xFF ) << ( random() % 24 ) );
            sd = random() % 17;   // small divisor always in range 1...16
            if( sd == 0 ) sd = 1;
            if( new_int_divide( i, sd ) != compiler_int_divide( i, sd ) )
                dummy++;
            if( new_long_divide( l, sd ) != compiler_long_divide( l, sd ) )
                dummy++;
  • I have posted updated versions of these functions here:
    http://www.programmersheaven.com/zone5/cat27/32144.htm
    The versions posted on the Keil forum contain a minor bug in that the remainder is not returned correctly. The versions at Programmers Heaven are correct and include a radix conversion function.
    I have posted some other nuggets which can be found here:
    http://www.programmersheaven.com/zone5/cat27/index.htm
    Each of my contributions has the epithet fast.
